Topaz Photo AI creates strong pillow distortion from Canon CR3 files.
The lens is fully manual.
I tried it with and without lens correction in Topaz enabled, see the [pics in the link], (Jottacloud),
the original CR3 and the two generated DNGs.
The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
sorry for the delay. I uploaded the files. “20240827_165448.110__R8_-2321-rawdenoise_withCorr.dng” is with enabled lens correction and has strong pillow distortion, “20240827_165448.110__R8_-2321-rawdenoise_noCorr.dng” is with disabled lens correction.
We’ve recently released a new version and would like to try updating you to see if this resolves the issue.
