I bought the newest version of Topaz the beginning of September. I was finally able to upload some pictures to my computer and try to process. When opening the app, noted that an upgrade was available and did so. Ver 3.2.2 was installed. The app immediately crashes now with any type file used, either as a plugin from photoshop or alone. A box briefly pops up that says “Topaz has crashed” and disappears. I am not very computer smart, but get by.
Needless to say, my frustration level is high as I have some lovely pictures to process. I recently purchased a Nikon z6iii, and have questioned if that is a problem, as photoshop will not open raw files from this camera.
Also if you can, please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this thread.
If you would prefer you can securely submit your files(s) to my Dropbox using the link below. Make sure to send me a note to let me know you sent something.
I just upgraded to V3.2.2 of Photo AI 3 today and am having the same issue as the above user. I’ve tried both reopening a recent file and dragging and dropping a new file and Photo AI shows the Analyzing progress bar for a few seconds and then crashes. I’m running Windows 11 Pro 23H2. Dead in the water until this is fixed!
I just uploaded the requested files to your DropBox. I included all my log files from yesterday. They’re from a number of different crashes, some new files, some previous, both JPG and TIFF. Hope there’s something useful in there!
Your machine’s RAM only shows 12 GB, but our minimum application requirement is 16GB.
It is recommended that v3.0.4 or v2.4.2 be used, which may give you a more stable application for this machine. You can use the following links to download these installers for your review:
Newer interface that all v3 have, but v3.0.4 does not have the new Autopilot updates
Can sometimes work on underpowered machines, however will be slower than v2.4.2
Let us know how that goes for you or if you have any issues in reverting to the previous versions releases. Also, if you have access to another computer, we can check its compatibility.
I realize I sort of injected my problem into the middle of someone else’s issue because I had the same problem. However, the cause doesn’t seem to be the same. I see he only had 12 GB of memory whereas I have 32 GB. Are you still looking at my data, or should I be opening a new issue in order to separate it from cadahare’s?
Hi there. I upgraded my driver as recommended and that seems to have done the trick. I was able to load a couple of pictures that I tried recently that crashed Photo AI and they seem to work fine now. I don’t have a lot of time to test right now, I’ll give it a good workout over the weekend and let you know how it goes. Thanks for the help!
Bill
