This was a long render of an HD interlaced source to UHD via Proteus and a 10x slomo via Aion. The clip is about 6 seconds long, When I came back after a few hours of rendering, the export queue said error and TVai 7.14 had hung and so had Explorer. The logs are at Logs
My System:
nVidia 3090 latest Studio driver 581.29
Windows 11 Pro 23H2 OS build 22631.5909
|Processor|Intel(R) Core™ i9-7960X CPU @ 2.80GHz 2.80 GHz|
|Installed RAM|64.0 GB (63.7 GB usable)|
In the latest log, I am seeing an error that seems related to a codec mismatch. Try changing the audio mode to “convert” and see if that allows the export to complete.
As far as the app hanging, it looks like the export was still processing in the background even if the UI was frozen, as the logs show the export was still running and was ended when the app was force closed. I recommend leaving it if it happens again to see if it will still export.
