Crashing and Freezing
The very first time I used the program I loaded a picture to max it out. My whole computer froze. I was forced to restart my computer because the whole thing was a brick.
After restarting the computer after letting it load everything I started the program again.
After attempting to do the same thing my computer locked up for another 10 minutes.
How do i find out what is wrong with my computer so that I can use this program?
Hi. Have you checked your system specs
Windows Operating System 10 or 11 - most updated version recommended
CPU Intel or AMD, with AVX instructions, released after 2013
System Memory RAM 16GB
Graphics Card NVIDIA
NVIDIA GTX 900 or higher, 4 GB VRAM
Graphics Card AMD
AMD Radeon 400 or higher, 4GB VRAM
Graphics Card Intel
Intel UHD 600 Graphics or higher, 16GB system RAM
For large upscales greater than 500MP, 24GB of VRAM or more may be needed.
Hope this helps
