Crashes when using Object Selection
Foto AI crashes whenever I use object selection to remove an object (here fence or collar).
I did send you the system profile. I am sorry for it taking so long :slight_smile:
Topaz Labs | Support Page
I updated Topaz using the build in update tool in the top right. The error still happens. Can’t you have a look at the eventlogs or smth like this?
Cute shot:
I guess it’s system-specific.
Please try to recreate this crash in Topaz Photo AI, then go to Help > Open Log Folder, please send me all of the files within that folder. You should be able to attach them directly as a response to this email.
You can securely submit your files(s) to my Dropbox using the link below. Please be sure to send me a note to let me know you sent something.
Dropbox File Request
