Crashes when exporting AdobeRGB TIF from Lightroom
Often, crashes occur due to hardware complications interferring with large image processes. Would you mind first sharing your full system profile in a private message so I may investigate further?
Sure, how do I generate a full system profile that I can send as a document?
Thank you for the update. One last question, what version of Gigapixel are you currently running on your machine?
The version I am running is 8.01
8.02 works. I had a job run to completion overnight: Generative low quality image.
The non-generative was never a problem. Generative preview always worked.
