Crashed while adding AI Remove's mask
Program crashed while adding (the third) mask on AI Remove module.
Steps to reproduce issue:
  1. Open a jpg
  2. Scaled to 4x, applied Recovering Face
  3. Enter Remove Beta module
  4. Add the first mask
  5. Perform remove task
  6. Add the second mask
  7. Perform remove task
  8. Add the second mask
  9. The program will quit without warning.
Topaz Photo AI [v2.1.2] on [Windows 10]
CPU AMD Ryzen 5 3600XT 6-Core Processor
GPU Radeon 8GB 5700XT
RAM 32GB
2023-11-29-19-49-14.tzlog (274.7 KB)
Why scale up to start with? You are causing more work and maybe is the reason why it crashed, is because of the size, there is a limit. I suggest you do the remove part first.
I was trying out the upscaling part and remove AI.
Since the remove AI need to be performed last, so what I did shouldn’t trigger the crash.
The only workaround was save the upscale image then perform the remove AI. Not so convenient IMHO.
