- When exporting, video appears to only render using CPU. When using FFMPEG command, GPU encoding is used.
CPU: Ryzen 9 5900X
GPU: NVIDIA 3080Ti
RAM: 32GB DDR4
3: 2024-10-17-23-31-57-Main.tzlog (49.8 KB)
CPU: Ryzen 9 5900X
GPU: NVIDIA 3080Ti
RAM: 32GB DDR4
The log you shared does not show a preview or process being run.
Can you open the Preferences Panel in the app and make sure that the AI processor is set to use the GPU?
File>Preferences>Processing
If it is, run a preview and export and then upload the new log here so it can be reviewed.
