Could not able to use Starlight 2.6 and Hyperion 2.5 in my local
logsForSupport.zip (146.8 KB)
Could not able to use Starlight 2.6 and Hyperion 2.5 in my local, i have rtx 4070 still getting this error. How to fix it
The logs are showing that the auth token is not being registered correctly when the models are being called.
Can you click on the Account tab and log out and then back in to see if that resets the token and resolves this?
