I am using the latest version for Windows.
I am using the copy audio setting.
The audio streams are copied, BUT the newly created video file shows all video streams with the language English. So the audio copy function is mostly useless for me, because I work on multi-language files…
This is a known issue and the dev team is looking into the language label issue. I would suggest a MKVToolNix for re-labeling the tracks.
Is there also a tool for mp4 output? ofcourse you can handle this with ffmpeg as command line, but is there something easier?
