Some minor color/exposure shift is expected with Topaz Photo AI at the moment. We are not able to perfectly preserve exposure, colors, and white balance but we get as close as we can to the original.
The File > Plug-in Extras > Process with Topaz Photo AI method has two functionalities:
sending a Raw (non-DNG) file will import the Raw directly and output a new DNG file always
sending a DNG or non-Raw file (JPG, TIF, PNG) will give the option to create a copy of the image or overwrite the existing image
If you send a Raw and a DNG file then the Raw will import directly and output a DNG file, the DNG file will display a popup to let you decide to overwrite or edit a copy.
