I imported a video and applied the SDR to HDR enhancement as well as the Proteus default enhancement because under the SDR to HDR option it recommends adding an enhancement to reduce artifacts. The input file is 11.2gb and the output file is 7.74gb. That seems unusual to me. I did notice the input file has a variable frame rate and the output file has a constant frame rate. Would that make that much of a file size difference and is there no way to output with a variable frame rate in Topaz Video AI?
Here is the media information:
Input:
General
Unique ID : 173710460674667473965242472109907550611 (0x82AF6AF4111C10F1184A40DC078EA193)
Complete name : C:\Users\Sub_z\Videos\Projects\Lossless Cut\Video - Part 01.mkv
Format : Matroska
Format version : Version 4
File size : 11.2 GiB
Duration : 17 min 44 s
Overall bit rate mode : Variable
Overall bit rate : 90.3 Mb/s
Frame rate : 143.851 FPS
Movie name : Video
Encoded date : 2025-04-08 23:56:20 UTC
Writing application : Lavf60.3.100
Writing library : Lavf60.3.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 78.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.066
Time code of first frame : 00:59:58:12
Stream size : 58.4 GiB
Default : Yes
Forced : No
Color range : Limited
Audio #1
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 3 870 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.88 GiB (26%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit rate : 3 303 kb/s
Channel layout : L R C LFE Ls Rs
Frame rate : 70.310 FPS (683 SPF)
Bit depth : 24 bits
Stream size : 2.46 GiB (22%)
Default : Yes
Forced : No
MD5 of the unencoded conten : A6B23364F5D980495548A809654662CE
Output:
General
Unique ID : 196284397910962891408588101081001357556 (0x93AAFFFD11A0829D713E01E6C95BF0F4)
Complete name : C:\Users\Sub_z\Videos\Projects\Topaz Video AI\Video - Part 01.mkv
Format : Matroska
File size : 7.74 GiB
Overall bit rate : 62.4 Mb/s
Frame rate : 23.976 FPS
Movie name : Video
Writing application : Lavf61.7.100
Writing library : Lavf61.7.100
VIDEOAI : Enhanced using prob-4; mode: auto; revert compression at 0; recover details at 0; sharpen at 0; reduce noise at 0; dehalo at 0; anti-alias/deblur at 0; focus fix Off; and recover original detail at 20. HDR Enhanced using hyp-1; exposure at 0; saturation at 0; and highlight threshold at 0.7
Video
Format : HEVC
Bit rate : 54.0 Mb/s
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.272
Time code of first frame : 00:59:59:02
Stream size : 6.69 GiB (87%)
Default : No
Forced : No
Color range : Full
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Audio #1
Format : DTS XLL
Codec ID : A_DTS
Bit depth : 24 bits
Stream size : 2.88 GiB (37%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : FLAC
Codec ID : A_FLAC
Bit depth : 24 bits
Stream size : 2.46 GiB (32%)
Default : Yes
Forced : No
