Conversion error, my AVI videos are not accepted
General
Complete name               : E:\AÑO 2009\CONCIERTOS\103.C+F 22-01-09 THE SMITHEREENS\VIDEOS\DSCF6309.AVI
Format                      : AVI
Format/Info                 : Audio Video Interleave
Format settings             : BitmapInfoHeader / PcmWaveformat
File size                   : 187 MiB
Duration                    : 5 min 30 s
Overall bit rate            : 4 746 kb/s
Frame rate                  : 30.000 FPS
Video
Format                      : JPEG
Codec ID                    : MJPG
Bit rate                    : 4 612 kb/s
Width                       : 320 pixels
Height                      : 240 pixels
Display aspect ratio        : 4:3
Color space                 : YUV
Chroma subsampling          : 4:2:2
Bit depth                   : 8 bits
Scan type                   : Progressive
Compression mode            : Lossy
Bits/(Pixel*Frame)          : 2.002
Stream size                 : 181 MiB (97%)
Title                       : FUJIFILM AVI STREAM 0100
Audio
Format                      : PCM
Format settings             : Unsigned
Codec ID                    : 1
Bit rate mode               : Constant
Bit rate                    : 128 kb/s
Channel(s)                  : 1 channel
Sampling rate               : 16.0 kHz
Bit depth                   : 8 bits
Stream size                 : 5.04 MiB (3%)
Alignment                   : Aligned on interleaves
Interleave, duration        : 1000  ms (30.00 video frames)
Interleave, preload duratio : 1000  ms
logsForSupport.zip (3.1 MB)
There is a currently known issue with AVI files being read correctly by the app that the team is working on addressing.
While they do this, the recommendation is to convert the videos using Handbrake to a different codec and format and bring back in for processing.
The problem is that this program The problem is that this program destroys the quality of images when converting from AVI to MP4 for example 1The program (Shutter Encoder) is the only one I liked the way it works with files. I think it’s one of the most comprehensive programs I’ve seen.
It lacks some power It lacks some power, but the quality is quite good.
But every time you do a process, you usually lose details of the video in each conversion.
To be able to do it with him Being able to do it with yours in one go would be the best option to maintain the maximum purity of detail.
I hope you can achieve this and solve the problem. I hope you can solve the problem as soon as possible.
You can use Shutter Encoder or Media Encoder if you want to. Handbrake is easier for more users but it doesnt have to be that app.
Either way converting the video from AVI is needed at this time for the Video app to be able to process it.
Once the team gets that issue resolved and we can support AVI files again then this step wont be required any longer.
What about using the Topaz Video CLI?
Or is it Topaz’s modifications to ffmpeg which is the problem? I would think it most unlikely the standard ffmpeg can’t handle these files.
Thanks.
Andy
Well, ffmpeg for sure can do this - as otherwise handbrake (that uses ffmpeg) wouldn’t be able to, either.
