Comment on 7.2.0. Release
HI - I managed to download both Photo AI 3.0.3 and Gigapixel 7.2.0 and both run fine so far. My impression is that these are two distinctly different applications. Which is fine, albeit puzzling. Every time I process the same source file in each program, the output is rather different. This might be due to the presets but it is unpredictable, sometimes one is better, other times the other. So in general, I am using Gigapixel for photographs without faces and Photo AI for face recovery. Sometimes I try both and pick the better output. It is fun while you “play” with it but difficult if time is of the essence. Thanks -
