Command line interface - settings instead autopilot
Please add more options to command line interface.
Let’s say I set my things in Topaz Photo AI and I want to encode 1000 photos this way.
I would run a script calling tpai.exe with settings. But I can’t. Because if I am correct it uses this autopilot each time.
Isn’t easy to add option to disable autopilot and use passed settings instead?
The CLI isn’t actively being updated at the moment since we’ve decided to focus on the GUI. For the time being, the CLI can only use Autopilot unfortunately. However, with the newer versions of Photo AI, you can change the default Autopilot settings the Preferences menu.
Is there a configuration file for the Autopilot settings? I’d like to edit the settings without having to open the GUI.
