The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
I have just uploaded the images to your Dropbox File Request. I chose a different photo as is lighter to hopefully easier to see the cast.
In answer to your questions:
The original image file = ML246958
The processed image. = ML246958-3 which shows a red/magenta cast
A screenshot or description of the settings panel so I can see what adjustments were turned on. From LR classic: File > Plug-in Extras > TPAI > Edit a copy
I have attached screenshots of not enhance, enhanced using Standard RAW and Strong RAW which to me shows the cast in both. That in Strong at strength 1 there is no cast but the cast gradually increases as the strength increases.
I’d like to get some more informaiton about the machine you are using where this color shift is occurring as I was not able to replicate this color shift on my machine. Please send me your system profile information so I can check if your computer hardware is up to date.
Its interesting that you could not reproduce the issue. The red cast does not occur with all my photos taken on the same camera body/lens combination.
Could it be that these photos being deliberately under exposed (due to the subject matter being a white bird against a dark background which otherwise would lead to over exposure of the bird) is a factor?
Just updated the Intel driver (Intel® Graphics Driver 32.0.101.5768 gfx_win_101.5768) as link below.
Unfortunately, still getting a red cast on that photo. I also tried another photo with no EV compensation and too there was a hint of a red cast. Not as pronounced but I could just discern a slight cast.
Would you mind taking a screen recording of this behavior so I can see exactly what is happening? I’d like to share this information with the developers for further investigation.
I used the same image (Little Egret) to show original and during processing the red cast happening with both RAW normal and RAW strong. That the cast was more pronounced on increasing the strength but was still present even at lower levels.
Thanks for trying to send in that video file, it appears that there was an error with the Loom recording and I was not able to open the file from my Dropbox, would you mind trying this again?
Thanks for sharing this information, I have included these files and Loom videos for our developers to review and see if we can get any more information as to why this might be occurring. I will be sure to reach out to you here on this Forum thread once we have more information.
still happens with TPAI 3.2. Not relly clear what the new features do regarding Canon RAW improved colour accuracy given the magenta cast. Anyhow to let you know, John wrote back to me (2nd Aug) saying he will let me know when this is fixed.
