When you use the brightness slider on the Color Wheel - the darker you go - the darker the Color Wheel.
When you go to entirely Black - the CW disappears!!! Perhaps the brightness of the CW should be independent of the CW color brightness slider?
Hi Jack, I take it that is Mac … could you raise a support request with a screen shot thanks.
