The colors in my Topaz Ai changed a lot when I calibrated the monitor in win 11.
They are strange and unnatural. After returning to Photoshop, they return to normal. What is wrong and where can I set the icc profile in the program to the appropriate one after calibration?
- The original image file.
- The processed image.
- A screenshot or description of the settings panel so I can see what adjustments were turned on.
You can’t set the ICC profile in TPAI, it should just use the default profile in the Windows Colour Management settings.
Try enabling sRGB Preview Fallback in the TPAI preferences, if it isn’t already enabled, then restart the program.
If that fixes the preview in TPAI, then it probably points to TPAI having issues with the calibrated ICC profile.
