Color Noise and Noise Reduction
Steps to reproduce issue:
I am disappointed with its ability reduce video noise even though I tried several diff options in Enhancement section, Also it does poor job with getting rid of color noise.
Dan
I just want to confirm with you that you are using Topaz Photo AI and not Topaz Video AI
I noticed in your post that you had an issue with the video noise.
Thank you for your quick reply.
I am no longer using Video AI. I do not notice improvements in improving old videos, improve sharpness nor noise reduction. I got the refund. Thank you. Hopefully in the future.
As far as Photo AI, though I have it I don’t use it after long try. The main problem with Photo AI is the color noise … I am fully satisfied with the individual Apps.
Dan
