I am seeing a color issue with Low Res in v7.4.3. I circled the area with green in the top area. It seems to be the Denoise that is causing it after the latest update.
Hi @dm5kmwf ,
I see what you mean! Artifacts like that sometimes appear when the computer is hitting performance problems. We see it most commonly when attempting to run large batch processes on machines that are on the lower end of Gigapixel v7 minimum system requirements.
In any case, I’d be really curious to take a closer look and try to reproduce what you are seeing in this specific case. Would you mind reaching out to me at help@topazlabs.com and we can go from there?
