Hey,
since the latest version 3.0.4 of Topaz photo ai has a problem that I had with an older version is back again.
When exporting the image to Capture One, the color balance is changed. The picture color is flat.
If you wish I can send you an example.
Can you please give an advice? software bug?
The original image file.
The processed image.
A screenshot or description of the settings panel so I can see what adjustments were turned on.
