Color balance great, Heavy color cast removal could be better
I would recommend that the balancing for heavy color casts is improved. When moving the slider to colder, the image doesn’t get colder and the color cast removal sort of breaks, leaving the image as the original with nearly 0 color shift. This does not happen with low color cast images, just ones with high color cast (sodium vapor lamps, daylight WB indoors).
