Close program problem
After adjusting image that was in adobe elements. The window won’t close. Using MacBook Prol
I’m not sure exactly what’s going on here. Are you able to use the plugin and export an image from Photo AI and import it into Elements? Are you trying to close the window with the red circle in the top left (Mac) or the X in the top right (Win)?
I found that I could find the way to close the window by tapping the corner of the screen.
Thanks
Jim Rowland
| tim.he Tim He Product Specialist
October 25 |
