The CLI is failing with the following output:
Change the following settings within the preferences panel in the app
Application settings:
Overwrite Files: 0
Recurse Directories: 0
Input File Count: 1
Output Folder: C:\Users\jdoe\upscaled
Output Format: JPEG
Jpeg quality: 100
Autopilot settings:
Auto apply filters: true (Forced)
Face Detection: none
Face Strength: 80
Face Parts: hair,necks
Sharpen Model: Auto
Sharpen Levels: medium,high
Sharpen Strength: 3
Upscaling Model: Auto
Auto Upscaling Type: scale
Auto Upscaling Factor: 4
Upscaling Denoise Strength: 3
Upscaling Deblur Strength: 3
Resolution Unit: 1
Resolution: -1
Remove Noise (non-RAW) Model: Auto
Remove Noise (non-RAW) Levels: medium,high,severe
Remove Noise (non-RAW) Strength: 3
Remove Noise (RAW) Model: Auto
Remove Noise (RAW) Levels: low,medium,high,severe
Remove Noise (RAW) Strength: 3
Remove Noise vs Sharpen: auto
Default Subject Type: Subject
Warning: failed to load Config_git.pl, something strange about this perl…
[ WARN:0@3,318] global C:\Users\Gregory.conan2\p\b\openc402aa59aeef85\b\src\modules\core\src\matrix_expressions.cpp (1334) cv::MatOp_AddEx::assign OpenCV/MatExpr: processing of multi-channel arrays might be changed in the future: core: inconsistency of addition for multi-channel Mat and Scalar · Issue #16739 · opencv/opencv · GitHub
exit status 1
Topaz Photo AI 2.2.0 on Windows
Hardware: i9-9880H, 64gb RAM, 1Tb NVMe, NVIDIA RTX 4000 8GB
