I’ve used the Windows version of the Clarify plug-in ever since it was introduced. It works perfectly well with the latest version of Photoshop CC. I recently purchased a MacBook Pro as my “mobile workstation”. I’ve been getting my Creative Cloud applications installed and configured and have gotten to getting Clarify installed. Imagine my surprise when I found it is only available via the Studio version. Downloaded it to take a look and I don’t like it at all! Is there anyway to get the classic plug-in presets installed with it? The ones in the studio version pretty much SUCK compared to what is available in the old Windows plug-in version.
The older versions are all there for download, remember though they are unsupported …
Note that the previous version of Clarity can also be accessed from the Plug-in menu in Studio.
