Circular polarisers and color casts
I use circular polarisers with a wide angle lense fairly often and there is often an effect on the sky color in that it can be different in different parts of the sky. Requires a bit of fiddling about with masks to make it look decent. It does seem something that AI could deal with.
https://www.photocascadia.com/how-to-fix-dreaded-polarizer-sky/
Thanks for sharing that link and idea! This does seem like something that would benefit our users workflow.
Make sure that you do not forget to vote for your idea :slight_smile:
