Looking at existing frame interpolation models, I definitely miss a model that created frames as precisely as Aion but did not sharpen them like Chronos does. It may be Chronos v3 or under a new name.
Dear Topaz, please do something like this.
I’m confused. Aion does some sharpening in that it tries to un-blur motion blur, but that’s not noticeable if you are using it to increase the frame rate of a video. It is noticeable when creating slow motion out of a video, and I argue that it’s even needed. Do extra-blurred objects look natural?
Chronos, from all my tests, does not blur unless it can’t figure out the motion vectors—and it falls into that a lot easier than Apollo and Aion. Usually I can’t use it because it makes random blurry patches in things like trees.
I don’t see how Topaz can understand your request to do anything about it.
So let me explain exactly what I mean. Both Aion and Apollo take the source frame and sharpen it before producing intermediate frames. Chronos doesn’t do this. As for me, such sharpening is destroying the film that I had previously so carefully improved with other models. That’s why for me the best model is Chronos.
Unfortunately, Chronos is not as accurate in creating new frames as Aion, it creates them much worse. Of course, ChronAio takes more time, but this is exactly the model I need for double the fps, for example, from 25 to 50 (not for slow motion).
I hope I have explained my wish clearly, which I hope a few other people share.
Interpolate before doing the other enhancements?
I want to do it after other enhancements.
Then you’re always going to have this problem.
Your answer makes no sense.
First of all, it is best to increase fps after making previous corrections.
Secondly, my life wouldn’t last long if I used the FPS boost first and then SLP.
At some point we always have to make a choice between saving time and getting the results we want. Based on your description of your experience, you appear to be at that point.
Therefore, I don’t see a major problem with Topaz removing the sharpening of source frames from the Aion model and calling this model Chronos V3 or Chronos Precise V1.
I may have a misconception about this, but it doesn’t seem like a time-consuming process – there’s nothing new here; Topaz don’t have to train a new model.
The “problem” is whether this is an issue for a significant number of users, or if it’s just you. I don’t expect Topaz devs to create custom models if I’m the only one who needs them. It’d be a nice dream, but in the real world I adjust my workflows as needed to get the results I want.
I’m not a fortune teller, I won’t read tea leaves, so I don’t know if I’m the only one interested in this model, or several thousand people. However, I have a feeling that many people would like to increase fps in HQ quality without unnecessarily sharpening the source frames and spoiling what they had previously so carefully created with other models.
