I can’t find any instructions anywhere on how to change the settings in Topas if my movie recording only has 12 frames (slow motion), but I want 18 frames in real time.
Good light
Erwin
Erwin Weiskirchner
You will want to use the Frame interpolation filter to interpolate to 18fps. You can type in a custom value in the field
