Can't upscale please help
  • I can’t get upscale. the other features like frame interpolation are working clearly.
  1. Your system profile
  • Windows 10
  1. Your log files (Help > Logging > Get Logs for Support)
  1. Any screenshots as necessary
We need more details. :eyes:
Can you share your full system profile?
hi, thanks for reply.
here is my full system profile.
thank you.
2023년 8월 12일 (토) 오전 5:35, ida.topazlabs via Topaz Community <noreply@topazlabs.com>님이 작성:
DxDiag.txt (146 KB)
Morning!
While you do have enough VRAM, I would still recommend using fewer filters at a time for now. Also if you are running other GPU-heavy apps you will want to terminate them.
Unfortunately, I tried only the upscale function without any filters, but I keep getting an error. I have enough VRAM, using the RTX 3090 Aorus Master 24GB. My CPU is the AMD Ryzen 9 5900x 12-core, and I have 128GB of RAM. How should I solve this?
2023년 8월 23일 (수) 오전 12:53, ida.topazlabs via Topaz Community <noreply@topazlabs.com>님이 작성:
and one more thing, artemis is working for upscale but Proteus didn’t
Can you please update to v3.4.1 and try again? You may have been running into a memory leak.
