I can mask Filters in Studio 2. However if I select a Look and just want to apply it selectively in an image, there is no way to mask for that.
In Studio I, the Looks (presets) appeared on one side but you had the list of adjustments that created them on the other side. In that environment I could mask wherever and adjust each more than just a general percentage slider.
Am I missing something? Is this planned for the future?
On the top line click the Mask button:
The the masking area will appear below:
Also, each Filter used in the Look can be masked separately.
They are there but I don’t like the way are located. Completely separated from processing picture…
Processing on the bottom and mask selection all the way on top…
Not Smart. Was good in Topaz 1…
Thanks. I was looking for a global mask within the Look… not a bad idea btw. I can see what to do now.
