After following the process to remove the iris2 tz files on my M1 Mac Ultra for the 3.5.0 bug, I cannot export any files. I can preview them fine but the export immediately errors out.
logsForSupport.zip (2.5 MB)
Hello,
Thanks for the log files. It looks like the app cannot access “/Volumes/Terra/”
You will need to add the app to the list of apps with “Full Disk Access” in system settings:
System Settings, Privacy & Security, Full Disk Access
