Can not disable face recovery - faces alwas recover
faces are always recovered ! even if i disable face recovery !
Steps to reproduce issue:
  1. run autopilot - face recovery automatically enabled , faces recover .
  2. I disable face recovery ! faces are still recovered
    3.WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Topaz Photo AI [v1.4.1] on [Windows]
@amir.barenholtz Thanks for reaching out and uploading those files.
I was able to reproduce the sample you sent. It looks like the face recovered-ness you see is actually a result of Remove Noise rather than Face Recovery. Try choosing the RAW Normal Model instead of RAW Strong and play with the strength of the slides.
