If you create a mask, and then crop the image, the mask does not move relative to the crop, so that the mask is now applied to a different part of the image post-crop.
Precision Clarity: visible haloes can be present at larger values of contrast sliders. This was not the case with the original Topaz Clarity plugin. (tested, confirmed.)
Precision Detail: visible haloes can be present at larger values of the detail sliders. This was not the case with the original Topaz Detail plugin. (Tested, confirmed.)
