PC version 2.6
When JPEG export selected and selecting folder where to save - dialog for mov file export appears.
It’s possible to overdo this by selecting folder for PNG export before and then switch to JPEG export back.
2.6.1 update
Now its possible to select folder for JPEG output but it does not allow to save in selected folder.
Instead it always creates another folder and save result there
For example:
My jpegs are in FOLDER
I select it.
And VEAI saves result in FOLDER(1)
