The title says is all
Hi, What is the AI product you are using, and the input file format and the output file format?
I use Exposure X5… Topaz Denoise AI is an external editor. I open a TIFF copy in Denoise. The tiff fole created by Exposure has all the correct Exif info. After processing in Denoise AI the TIFF shutter speed reads 0.0 sec.
I suspect this happens with more of the AI products but I’m not going to do our work for you. You can test them your self and test Studio 2 to see where and how the problem occurs. It is not a crucial issue for me, I’ll still use the products, but it IS a bug that you need to chase down.
I am a moderator on this user to user forum, my suggestion is you raise a support request at the main website where the engineers will look at it … it’s not my work either
