Brush settings (regular) from Lightroom Classic
Win 11. LR classic. I have been having this issue since v2.4 and keep being told it will be fixed.
On exporting from LR to TAI (though not when exported from Photoshop to TAI) the regular brush settings moves jerkily and lags significantly behing the cursor. Superpixel and Object selection works fine.
When is this issue going to be addressed. Nice to have some sort of definitive timeline. Thanks
Export DNG to TAI
Afterautopilot, try to alter selected part of photo using brush settings, regular
Topaz Photo AI [v13.0.4] on [Windows11, 23H2]
This was resolved in the latest version release for Topaz Photo AI!
Use the following link to update:
Topaz Labs | Support Page
Thank you John for letting me know. I have updated as suggested and the brush tool is now excellent though perhaps a bit too sensitive but prefer this to the jerkiness.
Apologies for not replying sooner but been in an internet free zone for the last 2 weeks!
