Blocky results sharpen
Standard and strong AI sharpen models are producing visible lighter squares in the image
Steps to reproduce issue:
  1. insert image
  2. apply strong or standard ai sharpen model
  3. check results (darker images show the lighter coloured squares easier
Topaz Photo AI [v3.x.x] on [Windows] (latest version)
  1. The original image file.
  2. The processed image.
Dropbox File Request
images sent the original image.
a screen shot of settings and the post process image. i deliberatly sent a slightly darker image to better show the issue .
you will notice
a lighter line along the wing of the yellow plane in the fore ground that goes up at 90 degree just before the engine
a pair of squares across the fuselage of the rear aircraft.
#NOTE. lens blur and motion blur do not give this effect but standard and string do.
i have checked its not a camera issue by attempting with a downloaded inage from the web and images from 2 diffrent cameras both give same result. Cameras tested. Canon eos 80d (main use) Canon 90d, and google pixel 6 pro camera phone
Thanks for sending that in, would you mind attaching a screenshot of the Selection option you are working with while using the Sharpen feature? You may need to adjust this option to help with this issue.
perfect timing i was just working on another image where it came up screen shot of the issue options enabled and the selection settings will be with you a few seconds after this messege via your drop box
