Block/grid Artefacting still visible in Topaz Photo AI 2.3.2
Hi all, the grid-like artefacting is still highly visible in Topaz Photo AI 2.3.2.
Steps to reproduce issue:
  1. Step 1 - use the program through the automate feature on photoshop.
  2. Step 2 - select Autopilot-recommended remove noise setting, set the sharpen setting to strong (with autopilot settings), and use preserve text.
  3. Step 3 - import it back into photoshop through the Topaz Photo Ai plugin and the artefacts will still be visible.
Topaz Photo AI [v2.3.2] on [Windows]
Topaz Labs | Support Page
