Bitrate not working manually
In the Codec Settings, there is a dropdown with default bitrates. I usually input my own, manually. I cannot do that now because the defaults cover up the box to input your own bitrate. There should be a ‘Copy’ option in there. The audio has a copy option. Other than that, please fix this or put an option in to copy original bitrate. Thanks
Hey Tom, instead of clicking the dropdown arrow option try clicking directly on the number to get the cursor and then delete the value to put in your desired setting.
For some odd reason, that’s not working for me either. No matter what I do, the defaults keep popping up. I used to do what you are showing and that isn’t working now.
Apparently my display settings aren’t letting me do this. If I lower my text scale, that actually works but then I need a magnifying glass to see my work. :laughing:
Thanks Tommy, sent that note to the design team to look into this for you.
Awesome!! Thanks very much for all of your help. :smiley:
