Big FPS Drop with Dynamic vs Manual Settings?
Was trying v5.3.6 and noticed a huge difference in FPS processing between Proteus parameter settings being in Dynamic vs Manual. Obviously I expect some difference if Dynamic is assessing each frame, but at 1080p going from 4 FPS in Dynamic to 14 FPS in Manual seems like a hell of hit for analysing and setting different parameters.
Wonder if anybody else has noticed and if it still does it in even newer versions?
Interesting. What I know is when you use “Rec. Orig Details” processing time increases
why is that?
rec orig details blends with original footage
