Thanks!
I will use Artemis MQ then.
I tried Staxrip but could not open the mkv file after that. Not even VLC could… strange… I checked “Source=Automatic”, “Field=GTGMC medium” and “Noise=DFTTest”. If the result is not that far superior there I rather stick to Topaz and have everything in one product.
EDIT: Interesting, I even get better results when using Proteus-9 with well chosen settings. Even more crispy but not too crispy picture here…
after nearly a year without touching Topaz Video Enhance I´m finally back to my project. I could never find the time. Now I realized there is even a version 3.0 but my upgrade plan expired 2 months ago… aaargh! So there is only the way to spend another $150?
Did anything change on my above workflow? I captured a few AVI files with Premiere from my Digital8 cassettes and wonder what to do next. I read somewhere that I could expand the videos to 4K and then use XMediaRecode to downsize it with a Lanczos filter to get a crispier picture in 1080p? Is that the way to go:
Dione TV
Artemis MQ to 4K
Downsize with Lanczos Filter
Or does anybody have a better way? Thanks for any help and sorry for the long quiet time…
EDIT: Just tested a bit around… Artemis Dehalo is good as Artemis MQ but with more natural color. Also I compared 4K-to-Lanczos-2K and straight-to-2K and first looks crispier.
EDIT2: The software doesn´t let me export the audio in the first DioneTV step, even if I choose “no fps doubling”. The button is grey… source is a avi-file from Adobe Premiere DV capture.
First I decide if I am going to capture them at 60p or 30p. Some customers like the fluid look. I use broadcast quality hardware / software to do that in real time.
I don’t like the results from de-interlacing with Topaz. It is not consistent and I don’t have time to mess with different trial and errors.
Regardless, I then use the Artemis MQ. Sometimes the video looks too artificial and then I’ll choose Artemis HQ instead. LQ is never used - it will look too plastic.
I find that older videos should never look perfect, but that is my opinion. I guess between analog records and CDs. They need some warmth.
I typically add some grain as well if it needs more texture.
