About Neat Video denoising:
Ok NEAT has several options for fine tune. What I never understood is if created NEAT profile gets aplied 1:1 to the entire video, or is there an adaptive functionality built in denoise happens to varying degrees. If I denoise a noisy scene with NEAT, then it’s too much for other scenes with lower noise level.
qtgmc is very good but even in draft in the minimum deinterlacing quality, it does not retain as much detail as muksun or msu with virtualdub. proteus v4 remains the best in my case for scaling by removing aliasing and artifacts without destroying fine details.
Yes, I see
Proteus v4 is worse than Proteus v3
I think the interlaced setting on Topaz need an upgrade, the dione seems too strong and i use alway protheus who make better job
If I use protheus in the first pass and gaia or arthemis in the second pass, on my dvd BFF the work look good
and why on the interlaced tab there are only dione, iris and protheus?
