I’m probably missing something obvious, but would dearly appreciate the answer. AI Gigapixel is one of the most amazing programs I have ever encountered. It’s simple to fine tune and produces truly amazing results. My question is, for images requiring similar processing re clarity, sharpness, noise- and artifact reduction, but not requiring enlargement, which Topaz program should I be using?
Try the Denoise AI and set it to use AI Clear (pull down box). For most pictures it will give excellent results. Let it set the sliders in auto mode.
I’ll give that a try. Thank you!
