Batch Processing - Keep the Queue
Today I had to process 21 images; and then after I wanted to check the output on a Samsung Frame and then adjust the output if necessary. So I loaded in 21 images in a batch; adjusted the first and propagated the settings to the remaining 20 - looked okay so I ran the output. At the conclusion, I was presented with [Close Window] - upon which I clicked - and then the 21 images were gone from the input batch. So, I had to repeat the whole process over re-appying my settings etc.
Can there be an option to retain all the source images to prevent an easy re-do ???
Asked - answered…i just found the option in Preferences that keeps the batch open after Saving.
Consider this closed.
