I was using topaz de noise for my .jpgs (post editing from raw files in light room) and it meet my needs well. Once it was no longer supported, I upgraded to Photo AI. It takes so long to process the photos and I am no longer able to batch process them. Is there a way to batch process like there was in de noise?
Thanks, I sent my info to the drop box.
Thanks for sending in that information.
I want to see if updating your GPU driver will resolve the problem, as there is a more up-to-date driver that has been released.
Please use the following link to update your driver: Intel UHD | Driver Update
Hello, I downloaded, installed and ran the intel driver support wizard and it told me that the UHD graphic chip is up to date (Version 31.0.101.2127). So, it doesn’t give me an option to install anything newer.
