Batch mode not applying GUI settings
Seems like Windows-Version has some kind of unattended option using the “tpai.exe”
Used the GUI-Version to set my parameters especially the export format for RAW images. I disabled the DNG-Export and set JPEG and Quality in the save dialog which remembered.
Workflow: Using Photo Mechanic with tpai.exe as default edit program for images.
Launching the edit from within PM the commandline version op TPAI starts doing what it is supposed to do EXCEPT exporting the Image as a JPEG. It still uses the oversized DNG-Export
Please enable us to either have a dedicates settings file for the batch mode or utilize the GUI settings in the same mode.
