Hello,
I have a folder structure with original jxl files (I will convert them to jpeg first since jxl is not supported by Photo AI, I am aware of this).
I would like to denoise all of them with the same denoising setting (they are scans made with a cheap scanner, all have the same noise pattern). Then I would like the result to be exported into an identical folder structure. Or simply exported next to the original file with a suffix. Or even overwrite the original is fine.
I just don’t want to have to process them one folder at a time and I do not want to have to recreate the folder structure by hand, there’s too many.
Is Photo AI able to do this?
