autopilot is not applied when the image is not previewed
Steps to reproduce issue:
- Open multiple images
- Check Select all
- Press Export NN images
Actual result:
Autopilot applied only on previewed image, all the rest are exported w/o any changes.
Topaz Photo AI v3.3.0 on Mac
Please take a screen recording of this behavior so I can see exactly what is happening.
Loom is a great free application for this: Loom | Free Screen & Video Recording
To put the Autopilot back on so it applies the suggestions automatically, please follow these steps:
Open the Topaz Photo AI as a standalone application.
Go to Preferences > Autopilot and enable Automatically apply filters to on and click Apply.
After you have done this, your application should operate as it previously did.
To do batch edits, please make sure you are following the steps below:
Click on the Select All checkmark
Select Apply Autopilot to apply your default Autopilot settings to all selected images.
Still doesn’t work. Please, see all your recommendations / steps in new screen recording.
Notice that in UI it shows new image resolution (enlarged), but in output file it’s the same old resolution.
system
(system)
Closed
7
