Auto selection not working
Version 3.2.1
As described by other users auto selectin no longer will select subject
Steps to reproduce issue:
  1. Step 1
  2. Step 2
  3. Step 3
Would you mind sharing some examples of where the Subject Selection option is not properly functioning?
Have already removed latest version. It was all photo. It would pic small random area some in the subject, but mostly dark areas in the back ground. There are post of other uses that have screen shot. Back dated to version 3.2.0, works fine.
| john.topazlabs John S Topaz Photo AI Owner
September 25 |
DxDiag.txt (96.9 KB)
Thanks for sending in that information.
I want to see if updating your GPU driver will resolve the problem, as there is a more up-to-date driver that has been released.
Please use the following link to update your driver:
