I did raise this with Topaz, I was told it has to go through the process, even if you turn the auto pilot off. Think it is in case you go into one of the processes.
The annoying thing is that Autopilot popup (that was added just a few releases ago).
I think they should simply not show that popup when autopilot is turned off. That would result in less confusion.
